Need speedo cable help, what is going on here....
Spoolin Around
The Crazy Cannuck!
Fellow Buick lovers, I am having a rediculous time finding a speedo cable for my GN. I
have been screwing around with GM for the past month and they don't know anything....
thought I had the correct cable, but the cable is too long and wrong end on it. I have
the AVC dash and my speedo cable is two piece, the GM cable only comes in one piece.
The buffer for the VSS goes between the two cables and the cables split right behind
the powermaster at the firewall. The lower cable is the one I need, it is about 65 inches
long with one end female threaded 1" socket and the other top end by powermaster is
male threaded flush, like a bolt. Does anyone know where to get one or what I should
do? I am stumped on this one. Does anyone else run the AVC dash with this cable? Is the
stock GN cable two piece or one? Thanks for the help.
:confused:
My '86 has a two piece cable like you described. Never measured it but it does have a split right behind the power master. Have you checked with bweavy? He seems to have a lot of GN parts and a good handle on what is going on with these cars.
I have a VDO electric speedo w/the transducer right by the pwrmaster too. My cable broke and i wound up going to Oreilly's and getting one for a Early 80's pickup. It fit perfect.
