turbobooster
- Nov 12, 2002
My ttype is throwing the vss code it's actually been there for sometime now, also my speedometer needle has also been faulty it doesn't read mph and once in a while it will bounce around a bit but most of the time it just doesn't move... To me it sounds like 2 different problems ill have to fix but I could be wrong that's y I'd like some advice first before I start backwards here if u will ... My question is can my faulty needle be the cause of the vss code coming on my scan aster? Or does that not have any affect on the vss? Where should I start with this problem?
