I have the same problem, and always have, and I dont have a huge IC. Just a Dutt neck. Plus it even did this when it had the stock IC. If I go higher than 14psi at part throttle, is flutters bad...kinda like a ta ta ta ta ta ta ta ta. Ive got some bypass valves here that I was planning on using, to make a dual bypass setup on the buick. But I think I'm going to run into tuning issues since buick wrote all the tuning code around having no bypass setup.
Ive always believed its the same thing as what gnx139 is saying. My homemade boost control causes the turbo to act like an on off switch. The boost comes on ridiculously fast, and having it at part throttle...(throttle blade halfway open) creates an air dam for a turbo thats flowing too much air too fast. I can get 20psi at half throttle, and about 3 extra pounds of boost at full throttle. I have to wonder how the engine can be flowing so much air at half throttle.
Honestly, I think going to a bigger TB will solve most of this. Alot more air is able to pass through the TB at lower throttle positions.
By the way, my boost doesnt bounce and never has. But the turbo does pulse really loud.
