Aug 4, 2007 #1 H hounddogs! Member Joined May 5, 2006 Messages 78 Need to replace one side of a dual fan setup. Approx 12" diameter, mf'd by Valeo, but I don't know what vehicle was the donor. The motor shaft that the hub mounts to has two flats on it. Price plus shipping to 66049. Thanks. Attachments DSCF0119.jpg 79.1 KB · Views: 79
Aug 4, 2007 #2 S SLOWSIXER JUST WAIT TILL I GROW UP Joined Mar 17, 2006 Messages 86 Which Side One Of Mine Went Out
Aug 4, 2007 #3 H hounddogs! Member Joined May 5, 2006 Messages 78 Driver's, but the ones I have look to be interchangeable. Not sure if the first post was clear--the motor's OK, just need the fan itself. If you think you have one, I'll do some closer measuring on the broken piece. Thanks!
Aug 5, 2007 #4 T turbojimmy Supporting Member Joined May 26, 2001 Messages 5,560 Check this out: http://www.turbobuick.com/forums/ge.../224565-ramcharger-fan-motor-replacement.html Jim
Feb 6, 2010 #5 J jsta6 John 15:17 Joined Nov 12, 2001 Messages 2,930 for those of you that have been replacing the motors, how do you get the fan blade off of the motor?
Feb 6, 2010 #6 H hounddogs! Member Joined May 5, 2006 Messages 78 There's something like an 8mm nut that holds the fan onto the motor. I can't recall for sure, but it may be a left hand thread.
Feb 6, 2010 #7 turbo nasty Turbo Dojo / MNTR Joined Jul 19, 2001 Messages 9,478 Guys seriously dnt mess with these fans they just dont last . I have been through 2 sets and even a few motors. They will only last a year or so before teh motors bearings start to die. Go with spals or teh dual jegs HTH
