Need wastgate actuator for 63-1 turbo
OneQuikSix
Hello all,
I just received my TE-63-1 turbo yesterday and need to locate a wastegate actuator for it. I bought the turbo used and it did not come with a stock-style actuator. Apparently, the modified stock one that came with my TE-60 will not fit; the bolt spacing on the compressor cover is different. Anyone know where I can order one? Here are the specs.
Compressor cover is 4"in/3"out
Exhaust housing is Precision A/R 0.85
FWIW, we need to know exactly what compressor cover your turbo has.
Over the years, that model turbo has had 3 different covers.
Is it the older H cover without the Precision logo, or the newer cover with the Precision logo?
Got any pictures by chance?
Patrick
As a matter of fact, it's the one pictured in this post here
http://www.turbobuick.com/forums/parts-sale/296634-fast-trans-more.html
It's got a 4" inlet and 3" outlet. It also has the smaller 10mm bolts securing the compressor housing. Hopefully that helps. Thanks for your reply.
That's the older style H cover.
We sell actuators with the correct bracket welded up for both the older and the new style H covers. We are also currently running a sale on actuators through the end of Sept.
You just need to specify that you have an H cover when you place your order.
HTH
Patrick
I think I'm bringing this thread back from the dead? But I have this same turbo 63-1 and need a wastegate that fits. Old style no logo
