Need Wide Band O2 Sensor Install Help.
BRAD_PADGETT
I have a Zeitronix wide band O2 sensor that I am installing. How do you get the wire from the downpipe into the cars interior? The plug beneath the steering column is filled. Thanks- Brad
you can go threw the fire wall either on the drivers side or the passenger side but it will be hard to put it threw that gromet. if you dont want to do that drill a hole.
How I did it
I pulled the counsel and drilled a big hole with the unibit. I picked up some gromets from the parts store. It worked out nice, my lc1 controller sits under the counsel perfectly. :D
Rick- If I understand correctly the counsel is where the shifter is. Let me know. Thanks- Brad
