Need you guys input
Me too! Probably the V4-R. I need that A/C, blowing cold! :)
Geoff
A V4 will work great for you guys. You sure could use the help keeping the air cool that is getting into the engine. ;) Not like here in BC, cold air is usually not a problem.:(
Seriously though, unless you guys have all the bugs worked out and your car running to its full potential (or very close) you should hold off on spending any $$ on the IC.
I only upgraded to the V4 because my stocker was leaking, but even then, I was running low 12's on the stock turbo, injectors, IC and Nitto's before I did it. Tune 'er up, and let 'er fly!
Good luck boys, hopefully see ya'll in December!
Clayton
