Chatmanboy
- Jun 25, 2009
Been having trouble with getting my car started for about a month!
Things i have changed: New crank sensor 86/87 with connector, cam sensor cap, upgraded ign module and coil pack to 86/87, and replaced ignition switch! with that being said my car still wont start and i cant figure out why.
Things i have done: I did the no start test, everything checked out fine. Fuses are good, im getting fuel, put a new module connector on from casper. wiring looks good under the a/c bracket. Did the cam sensor timing, made sure the crank sensor is in the right position. So im stuck and need help asap. Im moving this weekend and is trying to prevent of having it towed to the mechanic.
So any help would be appreciated!
