Needed billet atomizer injector offset table xfi 2.0 16 volt + plus systems
norbs
Classic fast, XFI, SPortsman & MS3 programming
I need some help setting up my billet atomizers, the fast stops at 16 volts I want to run these at 18 -20 volts, and presently using the fast supplied offset table my ve numbers are almost single digits to get a 11.5 AF ratio at idle. I started to fudge the injector offset table, but its all a educated guess... Any suggestions or sources for a higher voltage calibration.
Norb
I am out of town. Here's something off my other laptop you can try. If you don't make a table or this doesn't work, I can send you one something better when I get back.
any particular reason you want to run them at that high voltage??
YEs the higher the voltage the smaller the injector opening time, the lower i can run the injector PW at idle.. The whole idea of the volt booster and billet atomizer injectors was to run clean at idle .
Thanks I will try it today... wow .53ms@18 volts this is exactly what I am looking for....
Gotcha, makes sense
I'm not making any promises, but it should get you started. I try not to let me idle VE numbers get below 30 for better resolution.
Seems I have something else going on #5 cyl is wet. Here is the log
Here is what my volt booster looks like..........the signal is CLEAN as clean can be...........Yes it was expensive about $350 shipped,,,and worth every penny.. JMS Chip is the company, google it.
They make 3 models fan, fuel pump, and spark, all the same box just different voltages out, fan is fixed at 15 volts others go to 21, or 24 volts I think.
Fuel pump version......I think 21 volts is more than enough.....
The injectors are rated to 20volts , but I plan to keep it at 18 volts...
