Neutral balancer, headers, injectors, stage stuff
daves87gn
Hello selling some items i wont be using on new build
1. Stock headers w/ATR cross over, Headers from low mile car been off for a while no issues $200
2. Neutral Balancer, Stock balancer converted, bought used believe Webber did the work $130
3. 72 LBS injectors low miles i have two sets $200 OBO per set
4. 83 LBS injectors low miles $200
5. stage valve covers with AN fittings $125 http://www.turbobuick.com/forums/parts-sale/349323-stage-2-parts.html
6. Stage II timing cover has been painted grey at one point good shape $90
7. Gear drive for cam $100
8. 86 IC off 19K car very clean $100
9. 120 X 2 injectors (as in only 2 injectors) $80 for both they retail for 72 each.
all item are plus shipping
Dave
Pics
what brand are the injectors and where did you buy them from?
Which injectors?
The 120 are trick flow
the 72 are Siemens if i remember correctly will check part numbers on monday there at work
the 83 not sure will check on monday
Dave
I was curious about the 120s and where if I buy these two I'd be able to get four more.
