New 1/8th time 7.24 @ 87 mph
Hoping to get closer to that eventually little by little what boost for that mph
Good stuff nice runs, that's flying pretty dang fast. You know you're going fast in the 1/8th when you're trapping as fast as some do in the 1/4 hitting 100+ mph.
In the quarter you should be easily trapping well over 126mph without any problems with that last run scooby if you ran to the 1/4..
Based off how your 1/8 run went.
I ran out of injector and pump. Swapping out to 80 lber's and a 340 lph pump over the winter.
Dam! I'm leaving a lot on the table...5-8 psi and 8-5° timing...I'm wondering if I'm running out of pump on my single reds xp
What's your IDC showing on PL? I also use the Racetronix fuel injector hotwire kit.
Not running power logger yet unfortunately that's why
I haven't pushed the setup very hard but my fuel settings are maxed on my pump gas chip and afr won't go richer than 11.5-11.8
