SignUp Now!If you try to bend the lines any you will break the welds.. Mine broke when i was trying to tighten down the fittings i went another route.
I just bought a 6776 BB turbo, I have installed it but the Stainless Water Lines need to be bent to look nice to go to the water line on the intake. Does anyone make up a nice set of lines for this? Any ideas?
I'm using the water cooler lines that came with the turbo, and they have been just fine. Been off and on 3 times, and no leaks so far. Maybe I've just been lucky?
Hi Mark, I would like to purchase the waterline kit for the 6776 and also I am running a stock MAF and I need to convert from the 4 inch turbo inlet down to the 3 inch pipe. Do you have a number I can cal l u at?Did my homework today, do I pass??:biggrin:
