New 87 GN owner/project car
Hey Preston sorry your having some issues with the GN. A common issue but quick and easy is checking the IAC and TP sensor counts. Do you have a scan tool to check these? I checked everything on mine because I was having an idling issue as well which I found to be mechanical. Check the easy things first. Did it start after you installed the MAF translator?
just a quick update..I got the idle fixed...I put in new 42lb injectors and a TT 91 octane chip and of course it tried to run better but it didn't.I ended up finding the pcv valve bad causing a major vacuum leak.Now it runs so much better and I even left a little rubber down on the shop floor :D
Isn't Conway near the Old Man on the Mountain?? RIP, Near Lincoln? Was up in that area a couple years ago. Went to that trading post place with the trained bears.
yep thats were conway is....one day the old man on the mountain was there the next morning it was gone. :frown:
