New aftermarket MAF not working, likely or not?
PaulRV6
This is a new aftermarket Wells MAF that I tried and does not work, stalls as soon as I plug it in. What is the likely hood that it is no good? I believe I have read that it is more common than not. Thanks
From my experience, it’s a high likely hood of issues. My Wells coil pack and module was shit out of the box.
I like to get newer style oem from the wrecking yard and use the translator with these newer style maf units. I've yet to get a usable replacement maf of any brand to work. Not sure why they are so hard to calibrate or what the issue is but they just don't work for some reason or other.
Few years back i went through 5 brand new ones in a row that were no good, go for a lt1 and a translator
Unless it's 100% essential that you have a stock MAF because it's some low mile garage queen then the best solution as stated above it a Translator and LS MAF. Works just fine and has the added benefit of higher flow through it.
Plus they are readily available from most automotive retailers , unlike the stock MAF sensor
Maybe some one locally can bring over a working MAS for you to try and see if that's really your problem.
Its easy to miss diagnostic a problem and blame a good working part.
