I've been chasing around a charging issue for the past two weeks on my 87 GN. I would have to charge the battery up in order to get it started and then once it started the scan master showed the volts continuously decreasing until it showed 9 volts and started idling like crap so I would shut it off. Revving the engine did nothing to increase the volts so I assumed the alternator had gone bad.
Replaced the alt with a reman from auto zone and had the same issue. Tested the alt when running and it was only putting out 12volts which obviously wouldn't do too well to charge the battery.
Then I noticed the volt light in my dash is out and read on here about how that will prevent the system from charging anything. Bought the field fix from casper's but didn't help anything.
So I took the alt back to auto zone and got them to replace it. Had it tested before I left and it passed but they couldn't tell how much it was putting out.
Installed it today, hooked everything up the way it was before and as soon as the negative cable was put back on the battery the alternator started smoking a lot. Disconnected the negative cable right away and it stopped. And yes, I'm sure I didn't hook the battery up backwards. I've found people having a similar issue on other non-turbo buick forums, but the responses are not too helpful.
It's safe to say that I'm going need another alternator, but any ideas of why this happened or where to start troubleshooting?
Thanks guys.
Thanks guys.
