new base turn signal stalk
usetaboost
SAY CAR RAMROD!!
mine looks like crap. Think I might replace it since I have to pull the steering wheel anyway. No cruise, no delay wiper. Thanks
fyi the stalk just pulls out and pushes back in so pulling the steering wheel has nothing to do with replacing the turn signal stalk
Yes, just figured I'd replace it since I'm getting everything else prettied up.
FWIW i've replaced many cruise stalks with having to disassemble the column
before you pull the old thread a thin fish wire (about three feet long) through the little hole in the plug end and tape over it
remove the clear cable guard by sliding it down toward firewall
pull the old stalk out and pull the wire up
take the fish wire and thread into the new plug end and wrap some clear tape over it to eliminate the sharp edge of the plug
take your time and while pulling the fish wire down jiggle the new cruise wire and it will come out at the base of the column
push the new stalk back in
replace the clear cable guard
theres no cruise. I called around and can't find one with no delay and no cruise.
