Intercooled88s
Moderator
- Aug 10, 2004
GN Spoiler(GM not after market) all 5 pieces $175
86-87 MAF $80
GN Front bumper $130
GN rear bumper $100
Alum bumper reinforcement $100 for front , $75 for rear
85-85 ECM $40
86-87 ECM $60
Kenne Bell Ram Air canister and scoop $40
87 GN good running 109 short block $700
87 Engine complete, has a rod nock $2000
Engine frame mounts $35
Turbo Link V4 $200 (complete in case, used only 2 times)
87 Grey T-type upper door panels in good not New condition, no trim pieces $40 for the set
Passenger remote mirror $40
Blackout door handles $20 for both
85-87 GN seat belt set(10 pieces) $70
Grey rear sail panels(panels around the quarter windows) for t-top car in great condition $40 for both
Grey Third brake light $20
86-87 dipstickand tube$40
86-87 Factory Oilfiller tube and cap $30
86-87 Scoop for airbreather $20
N/A crank std./std. $40
Fuel pump hanger/sender $50
Turbo gas tank $40
T-top bags $35
blackout wheelwell trim $50 each
109 Block $300
crank $325
.020/.020 Turbo crank fresh from the machine shop $150
stock 8445 heads needing rebuild $40 a set
84/85 to 86/87 conversion parts(all the original GN parts you need to convert over from 85 to 87) $1500
BQ coded GN transmission 48k $300
BRF tranny $500
Stock 200 4r tranny pan $35
Oil cooler adaptor with nut $35
Timing cover $25
Turbo rods(2 dot) $40 a set of 6
Turbo flex plate $25
Turbo oil pans $30 each
84-85 ECM $50
84-85 control module $50
84-85 up pipe(after market) $40
Steering box $40
GN sway bars $30 each
windshield wiper assembly $15
Complete heater box $150
Non Key locking t-top $90+shipping for the set
GN tail lights with blackout trim $100
Quarter glass with blackout trim $80
3 piece windshield blackout trim $30
3 piece rear window blackout trim$20
Black wheel well trim $50 each
Turbo plastic wheel wells $80 each
Any other blackout piece e mail me
GN hood $95-$150
AC lines $45
Turbo shield $30
84-85 GN intake $40
86-87 fuel rail $35
84-85 fuel rail $25
Any year injector harness $30
84-85 valve covers $35
86-87 valve covers $35
cam position sensor just the lower part(no cap) $25
84-85 MAF $45
84-85 turbo adaptor $25
84-85 crossover pipe $35
84-85 Alt $30
8445 heads $40 a set
84-85 engine wire harness $145
86-87 engine wire harness $175
Any other harness on the car e mail I have them all
86-87 Power steering pump $60
86-87 AC compressor $70
86-87 Belt tensioner $70
86-87 Alt. $60
86-87 Main accessory Bracket $80
84-85 Main accessory Bracket $50
Small plastic guide that holds the posi bat cable to the lower front cover $20
Blue dash pad $120
Chrome and gray strips on upper door panels $25-$35 each piece depending on condition
I have all the plastic interior pieces for a marroon or grey car with either t-tops or hard top .
Nice grey arm rests $15 for both
Nice blue passenger visor with lighted mirror $25
Alalog gauge cluster $50
Gauge surround $35
radio surround $25
Stock GN radio $50
T-TOP trim around the t-tops on the inside of the car in Red, Maroon, or grey , all 6 pieces $100
87 GN steering box $40
Power window motors or power lock motors $10 each
E mail me if you need a part not listed Fortune628@aol.com I most likely have it.
or CALL ME at 413 746 9668(If you get voice mail best to just call back, I dont get to my voice mail often)
All prices are PLUS SHIPPING.
86-87 MAF $80
GN rear bumper $100
85-85 ECM $40
86-87 ECM $60
Turbo gas tank $40
T-top bags $35
109 Block $300
crank $325
BRF tranny $500
Timing cover $25
84-85 ECM $50
Steering box $40
GN hood $95-$150
AC lines $45
Turbo shield $30
84-85 GN intake $40
86-87 fuel rail $35
84-85 fuel rail $25
84-85 MAF $45
84-85 Alt $30
86-87 Alt. $60
Blue dash pad $120
Gauge surround $35
radio surround $25
Stock GN radio $50
