Franks86gn
- Nov 15, 2011
I just recently picked up a 20 bolt pan N/A engine # 25524140.  After some research I discovered the deck height is different than the 109 block.
I'm rebuilding this to use as an 86/87 application.
Pistons: Can I use TRW 2481F pistons ?
Head Gaskets: What head gaskets can I run to acheive stock Compression Ratio?
Any other info on this block or rebuild tips?
Thanks,
Thanks,
