turbofabricator
- Mar 7, 2004
I just finished installing a manual master cylinder from a S-10 truck. It is a bolt-on deal. I did fabricate a new push rod out of 1/2" stock. (Although, I figure you can get one from a Bone-Yard) I made it adjustable to set it up and then welded it after the final adjustment. I also swapped the brake lines so the rear brakes run off the primary side and won't bleed down on the starting line. (NHRA Stock Eliminator guys do this ) I then removed the combination valve on the frame rail and used an adjustable one from Wilwood, up top, where I can get to it easily. I also installed the line lock and used the stock brake warning light to illuminate when the line lock is triggered. When I was testing the brakes out on Friday (before the test and tune session that would be the maiden voyage of the 'Alcoholic Twins') I popped the right rear wheel cylinder and almost became a permanant fixture in the garage wall So, I also replaced the wheel cylinders with the trusty S-10 manual ones. Needless to say, I didn't make it to the track. I'll have to wait until the BOP (Buick-Olds-Pontiac) race this week-end in Bremerton, Wa. Now, All I have to do is pressure bleed them and give it a test drive. So here's a list of the parts that I used on the Twin Turbo T-Type brake modification:
1984 Chevy S-10 manual master cylinder
1984 chevy S-10 rear wheel cylinders-manual brakes
Wilwood 4 piston front brakes
wilwood adjustable porportioning valve
braided -3 front and -4 rear brake hoses
TCI Roll-Control
various store bought and custom fittings
stock powermaster firewall adaptor
custom grade '8' 1/2" pushrod
swapped brake lines on the master cylinder
TCI Roll-Control
