new build NO000000 START
Just my experience, but i put in new injectors one time and couldn't get it to start. Turned out that i didnt plug the injector harness back in. Just a possibility.
i did dig back there to make sure harness was plugged :) been back tracking everything , even re set the cam sensor today just to be sure :)
Does the fuel rail hold pressure after turning the key on for few seconds? If it does you can prime the rail the disconnnect the fue pump and then crank the motor over, If the injectors are pulsing the pressure will drop with no fuel pump. This is a way to check the injectors if you do not have a noid lght. If you dont drop pressure then you know the injectors are not opening.
I have seen a Coil Pack which was installed incorrectly on the Ignition Module.
Check to ensure ignition wires are where they sb also.
Good Luck !!!
Yes, disconnect the ignition module plug. Check for power on port p and m with the key on.
My car wouldn't start even though the cam sensor tool light was on, turned the sensor a bit more clockwise and she fired right up.
