I've been reading a lot and made some post here to get some Ideas and I think I have it down to 3 plans on what to do during my head gasket change.
THe car is a 67k mile 87 GN with basic mods listed in signature.
Other than # 5 compression checks at about 150 psi fwiw....
Plan is to pull the engine and clean the engine and engine compartment up as I go.
THe goal is a quick street car quick enough in street trim to beat 90% of the factory stuff rolling off the showroom and those with the typical mods I see around here...
such as tune, exhaust, and intake mods.... I conceed to ZR1 corvettes as I only have seen one...
Et wise I want a 11.50 or better car, mph Id love 120 mph in the 1/4 but 115-117 is my realistic goal...
I don't expect to run that any time real out of the gate.... I have made some connections with some GN guys not to extremely far and they will help me tune the car and I will probably take it to a dyno for tuning as well as the track if it holds up.
Ok PLan A
Full Throttle Gasket set with stock style head gaskets at about 90 bucks seems to be a smoking deal...
ARP Head Studs
Pull the heads and home port them based on information from some here and threads I found with pictures.
I have done a little head porting on my old Pontiac's with decent success so I am not totally green to this..
Purchased a new Razor Alcohol system for the car...
Purchase a roller cam set-up from full throttle 206/206 cam
Turbo will be a TE44( may have to upgrade later but will see where it will go )
I have a streched SLIC big neck intercooler going on the car too...
Caspers Knock alarm
Scan-Master to keep me safe tuning...(I have Turbo Link for real Tuning the scanmaster would be just daily driving monitoring I guess since everyone says I have to have one )
I am buying a spare block and set of heads that I plan to actually port on saving my originals...
THey had 50k on them before he swapped to GN1's so if they look good I'll use them. I am hoping to reuse everything on the heads
just new seals, springs and stuff for the cam swap.... I will hand lap the valves if the seats look good.
Plan B
Same as A except
Leave the stock cam in place....
Plan C
Same as A except run a new flat tappet cam in the 206-208 range ....
Are these proposed combos good ???
Cost effective ?
Thanks...
Hoping to get started next month.
Ok PLan A
ARP Head Studs
Caspers Knock alarm
Plan B
Same as A except
Plan C
Cost effective ?
Thanks...
