sure I got numbers
k-kit numbers - 258hr - k69-200-8
                         264hr - k69-300-8
                         269hr - k69-400-8
sk-kit numbers - 258hr - sk69-200-8
                          264hr - sk69-300-8
                          269hr - sk69 - 400-8
the sk-kit has a notation - *stock springs can not be used with this cam - springs numbers are - 26915-12 - premium springs
number is 26918-12
cl-kit numbers - 258hr - cl-200-8
                         264hr - cl69-300-8
                         269hr - cl69-400-8
again  - the cl kit has a notation * stock springs can not be used with this cam - spring number is 26918-12
I'm goin with the k-kit for cam number 264hr. the k-kit comes with
      264hr cam
      lifters
      matched valve springs
      valve locks
      valve stem seals
      timing chain set
this eliminates all the guess work with the springs and such
the sk-kit come with cam and lifetersand timing set
the cl-kit come with cam and lifters
all come with assembly lube,decals,and instructions
amazin what you find out when you read a book
hope that helps ya,
mouse
1987 gn short block almost done - now that I know which cam to go with - jus gotta figure out the rest of the combo
