New crank trigger wheel
anders
1989 TTA
Hi!
I am looking for a new trigger wheel because i am changing ecm for a Haltech one.
Is there any aftermarket wheels that will fit this engine,or can i use my stock some how?
or what have you that Uses the aftermarket ECM made whith the crank trigger ?
Thanks for any replay.
If you use a FAST.. you can use the stock stuff to trigger. My TTA had zero issues.
If you want individual cylinder correction.. run a distributor or coil on plug.. then will need a crank trigger.
