SignUp Now!More than likely he set the rod and main clearance to loose. He Probley set it up like A small block Chevy. I can set you up A front cover that will help get the psi up if you want.
so i should pull the cover and pump off and have it looked at ?can you tell me how to get a hold of chris hogeland about the front cover ?? thanks everyone for trying to help me here
For those of use that have lost the oil cooler....can we get the standard oil filter pump cover and still run the biggies?Puralator Pure1, Mobile 1, Baldwin, and of course Wix. And get a biggie adaptor if you don't already have one.
The adapter to run biggies with no cooler is just a ring. It has ID threads to match the cover and biggie external threads.
I've got a box of them around here somewhere but I can't remember the exact sizes 100%.
