That is why you IAC is at 0v...  It wont register until you start the car.  Now did you have the gas pedal floored? If you do then release it.  Your TPS should read .42v with foot OFF GAS PEDAL.   Adjust TPS, make the IAC adjustment that I stated earlier, the start car an give a reading.  I bet you will be happy!!
'87 Turbo T w/E85, 224/224, ported iron heads and intake, 80 lbs injector, TE45A, GEN II, TT and EXTENDER EXTREME G, XP Double pumper and something secret, 86 T-TYPE (Kenne Bell test car) and '11 Tundra Limited Sent from my iPhone using Turbobuick
