steve86t-type
Hey everyone. I have a turbo buick with some mods that include chip, 60lb injectors, maf, cold air intake, ta 49 turbo set at 15 pounds. Car was running great. I then decided to add 340lph pump, hotwire kit, 3inch exhaust, alky kit, adjustable fuel pressure regulator and boost controller. After install the car had an intermittent rough idle. Every few seconds the engine would shake and then stop but it was consistent. I drove it home and drove fine. Only in idle did the engine shake. I then got close to home which is about a 20 minute drive and the car started smoking grey smoke from the exhaust and stalled out. I believe I blew a head gasket. I kept the boost at 15lbs and the alky kit was turned off completely and the tank had no alky in it that's why the alky was turned off. I kept the boost the same as before. I was waiting for the meth and a new chip from turbo tweak to turn the alky on. Any idea why it would idle rough after installing those parts and also why I blew a head gasket after those parts were installed? Any input would be greatly appreciated. Thanks
