**NEW** GM Front Timing Cover 14 Bolt with **NEW** GM Water Pump (Modified)
TurboJan
This is a new GM front timing cover for a 14 bolt pan. It comes with a new GM water pump and all new gaskets for the install. The cover has had all the oiling modifications done and also has a new Kenne Bell Oil Pressure Booster Plate installed. It has been assembled and is ready to install. Everything here is new and in perfect condition. Cover was also deburred inside and out before assembly. I know I paid somewhere between $400-$500 for this cover. It is a nice set up..................$200
Onto the Next in line since it won't fit my 87T which apparently has a 20 bolt front cover.
Should it come available....
I’ll take it for an early block project. PM if others pass on it being for a 14 bolt block. Scott
Looks like Trashman is the only one left standing between you and it?? As I guess I didn’t read the ad well enough, as I’m in the same boat as Tirefryer since I have the later 20 bolt oil pan too!
Good luck with it, whoever gets it. But, I’m out as well.
Will the 16 bolt pan seal up with a front cover from a 3.8 even though a couple of the holes in the bottom of the cover won't have bolts threaded into them?
This one has been sold but to answer your question. GM made separate covers for the 14 & 20 bolt Block/oil pans. Some of the later replacement covers had extra holes to fit either block, but not as common.
Thanks for the input Merry Christmas!
