87 GN stock, 59k miles
My car stopped running under normal driving conditions. This has happened periodically before. I thought a new EGR solenoid solved the problem, but apparently not.
On the side of the road, I started unplugging and plugging in different sensors to try to narrow down the problem. When I unplugged the wire from the top of the charcoal cylinder behind the driver's side headlamp, the car would run fine. When I plugged it in back, it would die.
Any ideas? What IS the sensor? Could it cause this problem? It seems to happen after rain / carwashes. There IS some water under the charcoal cylinder after a rain, so maybe the sensor is shorting? Also: will it hurt the car to drive it much longer with that sensor unplugged?
Thx in advance
Thx in advance
