New Jason White Tranny and Dusty's converter (billet NL with sprag).....
313badbuick
A V6!!!!
Received pics from Don Cruz where my 87 GN is having plastic surgery done :-) the usual procedures 6262 by way of Bison, PTE SLIC, 60lbs injectors, razor's single alky kit, etc etc blah blah blah. Nevertheless, should run pretty decent when I get her back.
In your sig I see you had a Husek stage 11,did something go wrong with it?
Sorry but my sig does not state a Husek stage 1. Never had any of his items but I hear he sell great transmission and converters!
maybe you need glasses
i highlighted the script at the end of your sig thats in black
from your sig
1987 GN.:D HARDTOP STOCK TURBO, 60LBS INJECTORS, PTE SLIC, 212/212 COMP CAM, COMP CAM LIFTERS, LT1 SPRINGS, AFPR, 3IN DOWNPIPE, MAGNAFLOW MUFFLERS, SCANMASTER 2.1, GBODYPARTS DUAL FANS, B&M HEAVYDUTY TRANS COOLER,HOT WIRE KIT, 340WALBRO FUEL PUMP, TURBO TWEAK CHIP, SOON TO BE ADDED: 6262 (BISON) BILLET TRANS (JASON WHITE) PTC 9.5 N/L (DUSTY), PTE SLIC, SINGLE NOZZLE ALKY KIT (RAZOR).David Husek STAGE II TRANSMISSION, RAZOR'S ALKY KIT(SINGLE NOZZLE)
Clearly that is an admin error! I have never that information in my signature block. I went back to by signature block and clearly its not in there sir! Admins please intervene.
from your sig
I dont need glasses! Well not yet anyway ;)
load your sig an then highlight the entire sig as if you were going to cut it out and youll probably see it , it happened a few years ago when they switched to the xenofore board format with the dark backround
(y)
if you havent driven one of dustys NL you're in for a nice surprise
