OK..I DONT KNOW MUCH, BUT HERE GOES! THE ENGINE I BELIEVE IS ALL STOCK.. THE ONLY ADDITIONS THAT I KNOW OF ON THE CAR IS A TOMCO MAF, SOME KIND OF ALCOHOL INJECTION KIT THAT IS NOT HOOKED UP, VOLT BOOSTER, FUEL PRESSURE GAUGE, FUEL PUMP AND WIRING UPGRADE, AND SOME KIND OF THROTTLE RESPONSE THING. SORRY! AS FOR THE MAINTENANCE, I THINK I HAVE KEPT IT UP WELL WHILE I HAVE HAD IT. IT SEEMS THE OWNER PREVIOUSLY JUST BANGED IT AROUND..THE BODY IS IN TERRIBLE SHAPE. ALSO, THERE IS A LOUD KNOCKING NOISE WHENEVER I BRAKE WHILE TURNING..LIKE SOMETHING IS SLIPPING OUT OF PLACE? SOMEONE TELLS ME THAT MY BEARINGS ARE BAD IN THE FRONT? ALSO, THERE IS NO FRONT SWAY BAR RIGHT NOW.. AND WHEN I BRAKE HARD, MY CAR PULLS TO THE RIGHT? I DONT KNOW WHATS GOING ON WITH THAT THING. WHATEVER PIPE IS LOCATED RIGHT UNDER THE PASSENGER SEAT IS CRACKED AND AT TIMES STARTS TO SMOKE..IT COMES OUT FROM BEHIND THE FRONT PASSENGER WHEEL WHEN IDLING. WHITE SMOKE..ALSO, THERE IS A LOUD RATTLE FROM THE SAME AREA WHEN IDLING THAT SHAKES MY PASSENGER SEAT? THERE IS A DEFINITE RADIATOR LEAK AND OIL LEAK..FROM WHERE, I DONT KNOW. AND ONE LAST THING, WHEN TAKING OFF REGULARLY FROM A STOP, IT SEEMS THE CAR REALLY LAGS UNTIL IT KICKS INTO 2ND THEN IT PULLS REALLY HARD.. IS THAT NORMAL? I DONT KNOW IF THIS IS THE INFO YOU WANTED.. BUT THATS PRETTY MUCH WHAT I KNOW! ANYTHING ELSE I CAN ANSWER FOR YOU JUST LET ME KNOW! THANKS.
