I'm planning on assembling a nitrous/propane injection package for my car. My fuel system is already pretty close to maxed out, and after reading about propane's high octane AND low price, I'm thinking it's the way to go for a secondary fuel source for the nitrous. However, all my research on propane's application in a gasoline vehicle along with nitrous has netted no solid answers, and has basically landed me here at your doostep like a wet puppy. I hope you can oblige.
I think to keep this consice and easy to read I'll list my plans, instead of asking a string of questions, and let you guys point at any problems I might have with implementing them.
Basically what I have planned is a propane vapor injection system that is hooked up idependantly from the nitrous system. They will both activate at the same time, but will have seperate delivery locations and nozzles. The nitrous side will be pretty much standard with the nozzle located at the end of the intake spraying towards the TB. For the propane side I plan to use a 5lb DOT approved cylinder with a welding propane/mapp gas regulator with both bottle pressure and line pressure gauges. From there I will plumb a line forward and through the firewall to a standard fuel solenoid used in nitrous kits. This is one point that concerns me. Can a fuel solenoid designed for gasoline be used with propane safely? From the soleniod I would then run a line to a custom made circular spray bar placed mid intake, downwind of the nitrous. I'm unsure on whether I'll need several spray bars to flow enough propane vapor, but I'm hoping that if I can get close enough with the spray bars that all my tuning can be done at the regulator with PSI rather then jet sizes.
In my mind it seems like this crazy plan just might work, but since I'm unsure about even some of the basic things, I'm a bit weary at attempting to implement the idea without seeking expert council first. I'd really appreciate it if some of you that have experience with this could shed some light on this for me.
Thanks,
Thanks,
