New noise while cranking?
Haven't turned the cam sensor yet will be this weekend. Well I took the pressure gauge off, turned the car to on and went to under the hood and fuel was leaking from the vavle, I cut the car off went back under the hood and pressed the little nipple and the gas just eased out with no pressure. :confused: Now what?
Put your gauge back on and see if it holds press and how long, if your plugs are real wet your injectors could be stuck. And try the cam sensor still to see if it will start.
Plugs were no real wet the other day when I checked them. I can tell you this it leaks down fast in about 15 minutes guage would be back to 0. I will fool with it some more Sat. or Sun and update you guys then. Thanks for all the help.
Gary
I'm sorry that you are still having problems with your car I thought that you had gotten it running by now, well look I just got up and I ran across your post and now I;'m trying to fig how far is pearl Ms, If it is not far then I will be glad to come down and help you to see if we could get it going today because I know the frusration so hopefully you will get this post this morning
V6cious, I think I will take you up on your offer! Guys, worked on it for an hour or so yesterday, moved cam sensor about 100 times. It started 1 time and ran for a whole 2 seconds and went dead!? I don't think it had anything with me moving the sensor because it never did do anything but turn over after that. Just some popping.:mad:
Poping - definitey sounds cam sensor related.
Try a new one. I went thru 3 of them when I had my no start condition.
2 were brand new outta the box !
You can fry it real easy when you are setting it. Not sure how - but you just gotta be careful. Try a new one and the Casper's tool when you set it.
Your fuel pressure should hold for longer then is does though IMO. Maybe a stuck (open) injector or bad pump also...
