Racetronix
- Oct 1, 2001
Racetronix Turbine-Tech RXP340M - 340L/Hr High Pressure / Volume In-tank Fuel Pump
- Flows 340 Liter/Hr (90 US GPH) @ 43 PSI @ 13.5V *
- In-tank use only / submersible design
- Reliable and quiet turbine impeller
- Can be used with EFI or carbureted applications
- May be used in pulse modulated systems (PWM)
- Center-inlet design. Same fitment as Walbro GSS340M, GSS307M and GSS294M pumps.
- Each pump individually tested
- For gasoline (use with E85 will reduce life expectancy)
- Integral check-valve
- Over-pressure safety bypass valve
