Racetronix
- Oct 1, 2001
Yeah I get that. The fuel sender came with everything needed except for the sock so it might help some people out, like myself, if you put something like "We sell filter socks as well, it might be a good idea to replace yours while you have the pump out" with a link to this (your pump filter sock product page) Racetronix - Fuel Pump Filter Socks
I had a GSS307 and decided to go ahead and upgrade to the 340, so I just ordered the kit and replaced everything. The parts stores around here are terrible, and none of them could help me find any filter other than the stock one, which was a different size than the 307 used.
If you look off to the right of this page you will see pumps and a filter sock listed:
Racetronix - FPS-G7 - Fuel Sender, G7 SS w/Single Pump Mount
If you have a GSS242M, GSS294M, GSS307M or GSS340M you will require this sock:
Racetronix - FFS-122A - Filter Sock, 104x42mm 22mm ID, G-D
If you have a F20000169 you will require this sock:
Racetronix - FFS-122 - Filter Sock, 19mm ID, 104x42mm , G-Media
If you have a GSS307/340 (non-M version) without a machined end then it is not intended for use with this GM-style sender and pump mount.
Thanks for the recommendations.
