please have a look.
News flash "GM steel shim gaskets discontinued from GM". To remedy this problem RJC has designed a similar gasket to take the place of these GM steel shim gaskets.
The new RJC Stainless steel shim head gaskets look very similar to the GM gaskets.
We took all of the best attributes from the the GM gaskets and added some major improvements.
#1 We made our gaskets from 304 Stainless Steel. This material is over 3 times as tough as the mild steel the GM gaskets are made from. This grade of stainless holds a better memory and is more malleable. This means the gasket will crush better and seal better.
#2 We made the gaskets out of .040 thick material. This is over twice as thick as the GM gaskets. This means you no longer have to stack 2 gaskets to achieve stock 87 gasket thickness. This also means that the gaskets will be considerably more durable, easier to install and less likely to leak water or fail completely.
#3 This new design is the ultimate in stock block head gasket technology. We have put allot of time engineering these and it shows in the performance of these gaskets.
for more info please visit
http://rjcracing.com/RJC_Buick_Products/RJC_Head_Gasket_Kit/rjc_head_gasket_kit.html
