i just put my new th350 built by tci with a rev manule valve body, the stall is a pats 4000 10" stall all new, it also has a trans brake and a tci 2qt extra sump.
I put 1 qt in the stall before it was put on the trans, then ran the car thru the gears and nu , i took 8 more qt s this makes 9 qts, it is reading full . problem is first will move and try to spin the tires, but there is no rev at all i even tried to rev it to a fast 4000 and nothing.
is 9 qts low and my dip stick wrong , it was from the 200r4 that was in the car, i thought they took like 10-12 qt all new .
please help because if the trans wont work the car is sold i cant take a bad trans again 4 in a row with all my cars
