New to site
whitechocolate
Hello turbo buick community i am new to site owned buicks for years.i have a 1987 t-type with a water leak.leaks water out of block between trans and motor.any clues
Welcome aboard first. You posted in the wrong forum but have been moved to the new members section. Please enjoy the site and ask as many questions as you can to undestand how the car works. There's lot's of tech on here that will help you as well as members that will almost fall over backwards to help.
I'd go to your user controls and add some info like a signiture that tells people about your car as well as a location. We mostly like to help each other and it really helps if we know where you are. Check out your state section and say hi as well. This helps you find other members near you.
Now on to some tech. Sounds like you have a freeze plug rotted out in the head or maybe a bad intake gasket. You'll probibly need to feel around to see where it's coming from.
Welcome to TurboBuick.com, the biggest & the best of all of the turbo Buick forums / sites anywhere. & welcome to the Darkside, too.
welcome aboard , where are you located maybe others can help you look at your water leak
Welcome to the dark side . Your water leak sounds like what i had if you remove the inspection cover for the torque converter there a 2 freeze plugs on the back of the engine one of mine was rotted out in the back only leaked when hot the trans does have to come out and get the brass ones for replacement
