New Tranny Install
87bigcut
When I hook up my new dry th350 to the turbo motor how do I go about filling it. Can I just bolt it up and drop the motor/tranny combo in and fill it? Or is there some percedure I should follow. This is a new tranny and converter.
Thanks,
Joe
Start with about 5 quarts in the trans. Have a friend start the car while you are ready with the funnel and about 7 open quarts of ATF waiting. As soon as your pal starts turning it over start pouring. Once you get about 5 more in after the original 5, start checking the fluid. On a new trans, you definatly don't want the pump to be running dry!! I just did this procedure on my 2004R and all went well. I think in the end I wound up with around 11 or so quarts in the new trans and convertor, don't know how much the T350 will hold.
HTH
Thanks,
Joe
It would be wise to put a couple of quarts into the converter
before installing the converter onto the tranmission. Make sure that the converter is completely engaged into the pump.
George
Thanks George for filling that in, I forgot to mention the ATF I put into the convertor............
It's according to the size of the converter. I put 3 1/2 quarts in my 9 1/2" converter before I put it into the trans.
