- Aug 11, 2001
Yes the Air dam and dupont Kenne Bell filter with canister. It's the air dam that needs a little TLC.Ok thanks, Is the Kenne Bell ram air the air dam or what is it ?
Mario
SignUp Now!Yes the Air dam and dupont Kenne Bell filter with canister. It's the air dam that needs a little TLC.Ok thanks, Is the Kenne Bell ram air the air dam or what is it ?
Polished:
RJC/Accufab 70mm Plenum $130
Need passenger upper door panel and rear lower seat cover.
Cleaning out just about every thing. I will be placing the items on eBay as well. So first come, first serve. You pay actual shipping (3% Paypal). I still need to take some pics. Please bare with me as I’m not online every night. Once there is a bid on eBay, that item will have to be completed through eBay.
Brand New Chrome & Polished parts.
Chrome:
Southeast alternator $210
Fuel psi. regulator 90 deg. Stem $8
Fuel psi. regulator cover/cap $8
Polished:
RJC alum. Racing crank pulley $130
RJC alum. Racing water pump pulley $70
D.C. Tech alum. Turbo shield (Buick Racing) $230
S.S. EGR vacuum valve (cover for the electronic control) $20
New (misc. parts)
RJC stock valve cover spacers/extensions $80
Casper engine ground kit $40
Like new Performance parts (with low mileage).
Champion steel/iron heads with wire lock groove (O - ringed) $800 gaskets (x3) $100
Champion lower and upper intake (egr removed) $300
3 bolt ATR S.S. Headers w/hardware $600
Like new Harland Sharp 1.60 roller rockers (w/shaft support, maybe 50 miles on them) $340
60 Lbs. Injectors with Red‘s 107 chip with special options (for stock ECM) $300
Red’s double intank fuel pumps with hanger $400
Precision Industries multi-disc (7 disc) 35-3800 RPM stall with “0” pump and modified 13 vane pump $700
BG customs 62mm throttle body $90
BG customs stretched stock location intercooler with modified intercooler bracket (with minor dent and missing bottom portion of scoop) $500
BG customs 3” down pipe (with an extra pipe) $100
Kenne Bell ram air (needs some repair) $75
AVC GNX cluster with trim and sensors (7k miles) $750
Used parts
87 GN Dash w/Plaque no cluster & trim (latch broken on glove box, easy fix [no shipping]) $175
Shifter assembly with chrome stalk (chrome is no good) $15
Rock arms & shafts $55
Fuel rail $35
Lower intake $140
Upper intake $60
Throttle body $80
Valve covers $65
Stock pair of heads (8445 not shipped) $50 a set
Pro Stars 15x8 w/3.5BS with drilled holes $200
87 Black Grille (slight crack on bottom/back side, cant notice when installed). $150
87 Chrome Grille $100
Rear Tail Light (cracked lens) $40
Heater box complete (minor crack, look at pics/not shipped) $100
Windshield wiper arms (black) $50 pair
Inner fenders $100 each or $175 for both (not shipped)
Front sway bar $20
Gear box: (quick ratio) $30
Interior parts as well. Look at pics, if u don’t see it call or pm me. Interior parts must go, super cheap prices.
Hot air 84/85 engine parts must go as well, super cheap.
Pictures by Buicktime - Photobucket
Will trade close or equal value part for: Freshly rebuilt or new stock turbo, NOS roof rail weather stripping, new to very good shape front and rear bumper fillers.
I'll check my email tomorrow morn.{early} for the cluster. ThanksSorry guys, I was unaware that I would get such a big response so early. I was hoping that by close to the weekend I would get some inquires, but to my surprise there is a lot of people on line for the same item. At any rate, most of the items are still on the car (unless it's new) and need to be removed in order to take pics. I've been very busy and I am hoping to remove the parts before or by the weekend start. The items that I could take pics of, I did. I will post them tonight and send them to whom requested them. Those few items were the BGC downpipe, BGC Intercooler and bracket, Kenne Bell ram air and the AVC GNX cluster. I got home real late last night and did not post,so I would like to atleast address some of the questions and update the list tonight.
thanks for your patience, Mario
Chrome:
Polished:
RJC/Accufab 70mm Plenum $130 SOLD
New (misc. parts)
RJC stock valve cover spacers/extensions $80 SOLD
Champion lower and upper intake (egr removed) $300 SOLD
Like new Harland Sharp 1.60 roller rockers (w/shaft support, maybe 50 miles on them) $340 SOLD
BG customs 3” down pipe (with an extra pipe) $100 SOLD
Used parts
Fuel rail $35
Lower intake $140
Upper intake $60
Throttle body $80
Valve covers $65
Pro Stars 15x8 w/3.5BS with drilled holes $200 SOLD
Front sway bar $20
Gear box: (quick ratio) $30 PENDING
A/C Heater vent SOLD
Door Straps SOLD
Will trade close or equal value part for: NOS roof rail weather stripping, new to very good shape front and rear bumper fillers.
