New XFI ignition cutoff
I will modify the adapter harness. This should make the ignition cut off a 2 minute install.
FWIW: I am also modifying the adaptor harness whenever anyone purchases an eDash. It too, is just a plug and play
how hard is the install if you have the long harness for the xfi....can you post any details or attach a pdf maybe?
Approximately a ten minute install. Directions are included, but it's basically a ground, a power, and a signal wire that goes to XFI pin C7
Install is very simple. I used the pa enable on a momentary switch to activate. Works nicely
