...Fuel Injectors = 60lbs Injectors from Turbo Tweak with Standard 5.7 chip (Best bang for your buck).
If running Alky this is the time to let him know. If you select a 93 octane chip another chip would be needed for Alky.
http://www.turbotweakstore.com/ProductDetails.asp?ProductCode=1015
Great stuff but you don't need a different chip with alky. The timing curves are slightly different but a 15-17psi street tune will have the same fueling as a 25psi alky chip.
And def go 80's on injectors in case E85 comes into play down the road. Same reason to buy 60's over the past how many years is the same reason to just step up and get 80's now.
