Newbie help please!! Boost problems
Jcsellsf
got a question about my boost. I am a newbie so bear with me. At full throttle the turbo boosts to almost 20lbs then automatically drops to 15lbs then slowly creeps back to 18-20lbs. It is currently set up to boost at 22lbs. tuning with translator pro I also have a scan master. What are some of the things I should check on besides the obvious vacum leaks? I'm a newbie at this, had the car for a while and just starting to learn how to troubleshoot and tune on my own. Any help would be appreciated thanks in advance
Could there be a small hole in the rubber part of the unit? I thought that may be the case if it was a homemade one, but yours is a HD one.
