Hello everyone. I'm now the proud owner of a 87 turbo T that I got from my dad (kellyd). He had it for sale on here a while back. Here is a list of the mods it has so far,
Fuel enhancements (Pump, wiring, regulator, Boost a Pump)
Air Intake mods
Breathers
Hooker exhaust
Gutted Cat
Welded manifold
Vacuum brakes with two check valves
Big rear brakes
Snubber
Air Bag
Brute strength U-joints, balanced shaft
Drive shaft loop
New rear shocks
Gauges (boost, knock, scanmaster, oil, fuel pressure)
Front braces
New timing chain, front cover, oil pump, etc
New cam sensor
TE 44 TURBO
009s Injectors
Big Neck intercooler
Alcohol injection
Turbo Tweak Chip
Line lock
RJC Boost valve
New valve springs
RJC power plate
Biggie oil filter, Baldwin B9
New headliner
New door hinges
The car ran a 12.70 with the old turbo and injectors, so I am guessing it should be a couple tenths quicker now. Question is what mods should I do next. I was thinking it was about time for a downpipe, but I heard not to get the ones from postons or kirban, any advise? Also a set of slicks would probably help out a lot. Anything else I am missing? thanks
Air Intake mods
Breathers
Hooker exhaust
Gutted Cat
Welded manifold
Big rear brakes
Snubber
Air Bag
Drive shaft loop
New rear shocks
Front braces
New cam sensor
TE 44 TURBO
009s Injectors
Alcohol injection
Turbo Tweak Chip
Line lock
RJC Boost valve
New valve springs
RJC power plate
New headliner
New door hinges
