it's just a six
- Dec 27, 2005
Just wondering if anyone here has tried it w/their alky injection system?
SignUp Now!B-Stoff + M-Stoff = C-Stoff.wanna really go fast?
try "spiking" your alky mix with 3 or 4 DROPS of hydrazine, and call me the day after.
:biggrin: A.j.
Quite to the contrary, if you know how to tune with it.Stuck deep in the back of my mind is a special on top fuel I saw. I thought I recalled that Nitromethane burns slow but the detonation limit is real low. So it would be counterproductive to inject it.
Well I am old and my memory isn't what it used to be.
You're right about the properties. You're memory is still good.
You would not inject the nitro alone. You would be injecting it along with methanol. As we all know by now, alcohol does a good job of controlling detonation. That sets the stage for the nitro.So how can injecting something with a lower detonation limit help. It is an oxygen bearing fuel so I imagine that would help.
A 10% mix of nitro in your auxiliary methanol injection system is going to yield a much smaller actual percentage when your total fuel intake (overall mix of gasoline, methanol and nitro) is taken into consideration.I've done it.
10% Nitro w/ Meth you need to mix it in with the meth because straight Nitro will not mix with fuel it just won't atomize. I really didn't see a big difference but, it sure burns the eyes when you hit the purge button on the alky kit.![]()
Maybe I just needed to run more?![]()
