Made two runs tonite. Only difference was one run had a 35 wet shot, the other was non-nitrous.
Methanol was used for the wet portion. Runs were done on 93 octane.
1.538
4.446
6.880
100.52
9.003
10.797
124.80
1.656
4.482
6.835
104.05
8.886
10.627
128.07
Track was going south.. the drag radials were trying theyre best.. my brakes starting making a little noise after the second run.. so I called it a night. Both runs were shifted into OD to keep things the same, I should of held out a little longer.. but 6k while spraying.. I was chicken.
Pretty compelling.. The car really woke up... boost controller did its job.. this is the best 1/8 MPH i've had so far with the car, at a few lbs less boost. Runs were at 24-25 PSI. Launched at 3 PSI.
Stuff works.. now how greedy can I get
Hope the timeslips speak.. I'll see if I can post up the datalogs.
Lemme get the slicks I should nail a 10.3'ish
1.538
4.446
6.880
100.52
9.003
10.797
124.80
1.656
4.482
6.835
104.05
8.886
10.627
128.07
