Just picked up another project car... (87 GN)
The seller told me it needed a trans, so I got it fairly cheap. When I got it home and unloaded I took it for a long test drive.
The 1-2 shifts are late and harsh at light/part throttle and won't upshift at all during WOT.
I've played around plenty with TV cable adjustment on other TR's in the past and regardless of adjustment, the cars would always upshift.
This one just hangs in 1st at WOT and won't go to 2nd unless you lift off the gas. The shifts feel pretty good in all the gears when it does shift, so I believe the trans is healthy otherwise.
I've done a bit of searching, and the only thing I could find was a brief mention of a possible governer problem.
Any ideas ?
If I can get away without having to put a trans in this car I'll be REALLY happy.
Any ideas ?
