Hey all,
About a week ago, I popped a T-stat gasket and repaired it. I get done and I had no boost....again!!! A while back, I made a post about it not making any. It seemed to fix itself after a while so I thought it might be a vacuum leak on one of the lines to the TB from the PCV. (had a crack in it) I fixed that...still nothing. I figured it had to be the wastegate actuator. Bought a new one. Still nothing. Played with FP a little...nothing. You get the idea.
I have a TA-49 that is retrofitted to a hotair config. (I was wrong in saying it was a TA-33) I sold it to a friend of mine and bought it back when he wussed out and converted to an 86-87 setup. He had the turbo clocked down a tiny bit. When I put it on, I noticed the arm from the actuator had to be bent upward a little to get it to work. Is there a chance that that might be my problem? Does it need to be in a certain position to work correctly? Would that explain why it worked and then didn't? Everything is correct, even the infamous "Y". Could a bad MAP be to blame also? Any input will help. I'm at a loss.
