No Electricity To #5 Injector.
At the injector connection what am I looking for?
1-A constant Ground?
2-A Constant Positive?
3-A pulsating Ground?
4-A Pulsating Positive?
Let’s assume it’s not the injector harness
Which wires are the ones to be checked at the ECM?
Thanks Guys
David
The injectors receive a constant 12v on the brown wire to them, and the other side would be an active ground (pulsating as you refer to it).
#5's active side is a blk/wht wire.
No, it changes to a tan wire at connector C111 that goes to B12 on the ECM.
no it some how pulled out of the CPU.
and
thanks for the work on the injectors they look good and work great.
David
