no fire injectors
V6cious
I need to know what wires to check for a break that controlls the injectors and what sensors to check
probably a blown fuse under dash labled efi
did you hook up a scan master incorrectly?
if the fuse was blown would the check engine light still come on with the key on
yes i believe it will
if you shorted something out under the dash, then the efi fuse will blow-
the plugs are dry correct??
yes they are and the fuel pump does not come on also so I'll check the fuse and see what happens
Sounds like a fuse, or, you forgot to plug the ecm in (orange wire near the battery).
