No Fuel Pressure?
TinysTurboPerf
RUTHLESS
I was leaving a golf outting the other night and drove about 1000 yards and my car died. It would crank, but never started again.
I looked at the fuel pressure gauge 0 psi.
The car has new fuel pump about 2 months ago and new injectors (stock).
I figured I would check with the relay and test lead to see if I could get the pump to at least turn on that way.
If the pump does work this way, it would point to the relay or ecm?
Any help would be good.
Jason
hey what up about a month ago my car did that to me it was a relay for my hot wire kit? then 2 nights ago it did it again this time it was the computer..my guess is it your computer if u dont have a hot wire kit ! i replaced my computer and the car runs 100% better good luck..greg
also i found out what cause my ecm to go bad.i have a normal turbo regal window leak and it got to the computer and corroded it.so u might wanna check that out lata..greg
Check the ground wire located in the trunk(by the driver side tail light where the trunk floor falls into the quarter panel). It is a little black ground that can get knocked off, like when you might throw golf clubs in the trunk. I did the same thing with my hockey equipment a few years back. My gas gauge pegged full when this happened and I had no fuel pressure.
